vcVolumeSensorTestMethod
Module: vcBehaviors
Parent: Enum
Referenced by: vcVolumeSensor.TestMethod
How to access:
import vcBehaviors as vc_beh
vc_beh.vcVolumeSensorTestMethod.<ENUM_VALUE> # replace <ENUM_VALUE> with the desired enum value
Enums
ValueDescription
BBOX_CENTER_INSIDE
Bounding Box Center Inside triggers if the center of a colliding bounding box is inside the sensor's volume space.
BBOX_FULLY_INSIDE
Bounding Box Fully Inside is triggered if a colliding bounding box is completely inside the sensor's volume space.
BBOX_INTERSECT
Bounding Box Intersect triggers if the bounding boxes of any geometry sets in a component are inside the sensor's volume space.
PRECISE
Precise Test triggers the sensor based on the geometry of a component, for example edges and faces.
